Get your PCM reflash done!!!!
I just had my PCM reflashed per TSB 4-21-14. I was lucky enough to not have to bitch too hard to get it done since I work at a Ford dealer. The latest update as of 8-10-05 was 5L3A-12A650-CGB.
I must say that I noticed an imediate difference in throttle response. I don't know if this is going to cure the tranny feeling like it went into neutral or not since I just got the reflash and the tranny only did that one time. I also decided to add a K&N panel filter to see if I can get a little better fuel ecconomy like some others have.
I'll be able to comment on the gas mileage in a couple of days after I run through this tank of gas. I could only go about 3 days before having to fill up before the reflash and K&N. It would be nice to get an extra day out of each tank full.
Originally Posted by noname05
any difference in drivablity with the k&n filter or you cant tell cause of the reflash?
If I do get a little fuel ecconomy to boot I'll be just thrilled.
Had mine done last week, definately gave me more throttle response and pep off the line, the calibration that I got is 5L3A-12A650-CLB. Wonder why its different from yours?
I keep reading about the reflash on these posts. Does this only affect certain build dates, because mine is a 3/05 build, and Ive never noticed too much throttle lag.
Is this still something I should have done? Sounds like it adds power, which is always good...
My build date is 4/05 on mine. I have an Xcal2 on order so I was wondering if I should even consider getting a reflash done. If I did get a reflash, it would be overwritten as soon as I installed the Xcal2 tune correct?
