OEM bugshield on 05 crew
Old Aug 8, 2005 | 02:26 PM
tmanscrew's Avatar
Exclamation OEM bugshield on 05 crew
I wanted to see if anyone out there had purchased an OEM bugshield that has the F-150 emblem on it? If so, are you having any problems with the way it mounts? Mine squeaks bad enough that you can hear it in the cab while driving. I was kind of leary of the way this thing mounted when I looked at the instructions and almost sent it back, but I figured that it must be okay since it is an OEM product. I know there are not a lot of mounting options considering the way the hood is designed on the 05 trucks, but do any of the other brands of bugshields fit a different way than having a metal clamp that slides onto the hood on each side and that is it as far as holding it in place? Any help or advice is appreciated.
Old Aug 8, 2005 | 02:36 PM
jztbcz's Avatar
I have one, ( though it's an '04 ) and I was warned by a friend who had the same problem your talking about ( squeak ) BUT after looking at it while installing I decided to use some washers on the bolts to shim out the space where the guard isn't.
( some people put them on too tight and you can see the flex where the bolts are on the grille surround ) I've got an excellent fit, no noises, no anything, real nice I like it...
Old Aug 8, 2005 | 04:11 PM
-TXF150-'s Avatar
I had the same problem, I was hearing a cracking sound that sounded like it was comming from the dashboard at aroud 45-50 mph. I pulled the bugshield off, and guess what the noise was gone. It has been sitting in my garage ever since.
Old Aug 8, 2005 | 05:54 PM
67L48's Avatar
When I bought mine a month ago, the dealership had installed a bug guard, but it wasn't the Ford one. They had installed a Lund (low-profile, I think). I haven't heard any noise from mine. Don't know who makes the F-150 bug guard, but I would guess that it's either Lund or Autoventshade.
Old Aug 9, 2005 | 12:35 PM
Inline6's Avatar
Maybe I lucked out, but the low profile F150 guard on my 04 does not make a sound.
