Ground Force Drop ! (RAMSST)
Old Aug 6, 2005 | 06:24 PM
04Superscrew's Avatar
I recently purchased a Ground Force 1.5F 3.5R Drop Kit. I am worried about the clearance with 24's. I know a 2 wheel Drive F-150 Has no problem with clearance with 24s but what is the Ride Height in inches from Ground to Fender lip? Mine is 40 inches with a Daystar. Soo I wondering if I should just take the daystar off or if I should Install the front drop too?> ANyone with some #'s on ride height of a 2wd Would be Great!! Or if anyone has Installed this ! THanks!!
Old Aug 6, 2005 | 06:58 PM
asinatra's Avatar
We need tire size to help you, rim size means nothing...
Old Aug 6, 2005 | 10:00 PM
305/35/r24
Old Aug 7, 2005 | 11:05 PM
RamSS/T's Avatar
I will measure from the ground to the middle of the front fender on my truck tomorrow for you. Like you know my truck is a stock (front) height 2wd truck, and if the truck was any lower they would scrub when doinga tight turn. I am really not sure how that would relate to a 4wd though. There is a guy here local that has a FX4 with 24s and he SAYS he has a 3.5/2 in drop on his and it doesnt scrub, but it looks like its the exact same height as mine.
BTW the tires are around 32.7 inches tall.
