Tsb 4-21-14...
Tsb 4-21-14...
...isn't available for me! That's what a tech said at my local dealership. I am going in on Wednesday to get my 3,000 mile scheduled maintenance (oil change + tire rotation). I also asked him to re-flash me, and he said it is available on 5.4s only - not the puny 4.2s such as myself.
Is this true?
If it is, how can I fix my throttle lag issue? Am I SOL?
If it can in fact be done, he has another thing comin'.
Is this true?
Originally Posted by SAJEFFC
You shouldnt have throttle lag toddzilla, the 4.2's have a regular throttle cable and not the dreaded throttle by wire.
Originally Posted by ToddziLLa
So, can you verify this Qunitin?
Am I SOL with my 4.2?
Originally Posted by Intel486
SOL how? You can still get aftermarket tuners from Mike and others.
I was just wondering if I am SOL in regards to TSB 4-21-14 or not.
I have a copy of TSB 04-24-14. It does not cure anything that may be wrong with your vehicle.
It is instructions on how to reprogram or replace PCM's. It has no new programs in it.
It covers various Ford vehicles from 1997 through 2005
Calibrations for the 4.2 aren't as critical as they are for the 4.6/5.4, since the 4.2 still uses a mechanical throttle cable (I think?). Like Newt said, 4-24-14 just outlines general PCM reprogramming procedures and tips.
I'm I understanding correctly. There is a way to correct the throttle lag on the new 5.4. If so, can anyone tell me how. I just got this puppy bout 1 week ago and noticed the lag right away.
Originally Posted by Preyhunter
Do you have any slack in your throttle cable? Maybe removing the slack, if it exists, would help you out some.
4-24-05 is just a general outline as to what to do to ensure accurate, troublefree PCM reprograms. The calibration data itself is stored on Ford's WDS or PDS scan tools, the former of which can lock up if you look at it the wrong way. WDS can be kinda sketchy at times. If it locks up in the middle of a recalibration, the data may be lost, at which point the PCM will have to be manually reconfigured using what Ford calls "As Built" data, the information that was originally used to configure the module in question. Then once that's taken care of, the latest calibration is normally uploaded with WDS or PDS.
