I need help from an expert about tires
I have an F-150 2004, I installed an leveling kint in the front so its lifted about 2.5 inches, I would like to know what is the biggest tires I can put on without changing the factory rims.....thanks
thanks g
thanks g
Yeah, 35x12.50's is the largest you can go. If you don't plan on more lift in the future, I'd stick with 33's and add wider aftermarket wheels a little later.
325/65-18 or 35" on stock 18"x7.5" wheels WILL bind against the lower control arm. .25" spacers will reduce them to slight rubbing near full-lock. 33" tires will have no clearance issues whatsoever.
[/IMG]
