coin holder replacement part 2
ok everyone, here is a link my photo gallery, look at interior mods. I could not figure out how to post the pics right here. tomorow I will post part 3 the installed photos.
https://www.f150online.com/galleries....cfm?gnum=5934
Sweet! where did you get the clock? Also, I just bought that same sub and was thinking about installing it there also. How is the performance? I figured it would give plenty of thump for a truck. Was it easy to install? And gow did you get that coin holder out?Please get back to us with details on your mods! It looks great so far
Later,
Luis S
Later,
Luis S
Hello everyone, Ok here are some answers to some of the questions, I know this is off topic, But the sub was a pretty easy install, But, I changed out the whole system so it was not like wiring to a stock stereo, There are preouts for the sub on the back of the stereo, Then all you have to do is provide power, ground and run the wire that turns it on to the stereo,As far wiring, I took the jack and it's mount out, there was a hole in the carpet and I used the mounting bolts to ground the sub,I then took the middle seat out, there was a hole there also, so I just used a clothes hanger and ran it under the carpet and fished the wires through, It was pretty easy to install, It just took a little time. As far as sound goes, It is really an amazing item, I was suprised at the amount of bass this little thing puts out. It won't blow the windows out but it was just what I needed to enhance the rest of the system without taking up to much space, I found it at Etronics, It was around $180.delivered,, As for the clock, I found it at summit racing for around 65 I think, it was about $10.00 more then the rest but it has the ford logo, Just go to the summit web site and search for clock gauges, then you will see ford racing click on that and scroll down, there are 3 styles for different taste, Wiring is pretty easy, Ground and power, I will piggy back off of the Assesorie plug on the right side of the radio behind the dash, the light will hook to my stereo since it a a wire that hooks into the dimmer It will dim the light when I turn the lights on at night.
The coin holder just pops out, But believe it or not there was a dead headed wire attached to the back, I am thinking that it is for the 4X4, and the wiring harness is the same, If it has power I will use it to power the clock, I will know tomorrow when I do the install. I will keep everyone posted, Also If anyone get the amp, you can run main power piggy back off of the rear seat assesorie plug.
I am not sure if I covered it all but I will keep everyone posted.
YooHoo, I got it in today, it was a piece of cake. I wired it into the power wires for my stereo, and I wired the light into the dimmer wire on my stereo so when I turn my lights on it light up.I had to use a razor knife to trim out some of the area on the dash piece but it was not a problem. I still don't know how to put the pics in here so I am putting the link to my album, Go to interior mods.https://www.f150online.com/galleries....cfm?gnum=5934
