Clarification on 4X2 Leveling Kit Please
I'm sorry, but I've been using the search for the past hour looking up information about leveling out my 4X2 and got stuck on something. Some fellow 4X2 people use 2.5" lifts while others did 2" lifts...so I gott a little lost. Considering that I plan to get airsprings, would a 2.5" bulldog the truck? Is 2" the better option for 4X2s ? I know this topic has been discussed numerous times, but I just wanted some peace...hoping that I wouldn't f'up my truck
Originally Posted by wandell
I would go with the 2.5 inch kit and add a block to the rear to adjust the height to where I wanted it.
sspangl, thanks for your input, I will definately take it into consideration.
Yeah, a 2.5 inch leveling kit and 2 inch block in the rear would put you at about the same height as a stock 4x4. However, you may only need a 1 inch block if you want the truck closer to level.
Originally Posted by Newt
Does anyone know of a leveling kit that lowers the rear instead of raising the front?
