Brake pedal location
Old Jul 20, 2005 | 08:45 AM
Jub Jub's Avatar
Did it take some getting used to the location of the brake pedal? I notice I have to pick my foot up and pivot so I can get my foot centered on the brake. It seemed akward at first but I think I'm getting used to it.
Did you all notice it or is it just me?
Old Jul 20, 2005 | 09:06 AM
lariatf150's Avatar
One foot driver or two? I noticed no weird issues. I drive two feet. Left foot ready all the time for the brake and right foot for gas only.
Old Jul 20, 2005 | 09:24 AM
Jub Jub's Avatar
One foot here. It's the way I learned since I drove mostly manuals all my life.
On my 95 F150 it was a simple transition from gas to brake by pivoting on the heel. Now I have to physically lift my foot onto the brake pedal. Like I said, I'm getting used to it!
Old Jul 20, 2005 | 09:38 AM
norman311's Avatar
It's not just you Jub Jub. There's a couple of threads here dealing with this issue. Seems like the brake pedal is more suited for shorter people than for tall guys with big shoes. It took me awhile but I got used to it. Sure wish somebody would come up with a easy way to more the brake pedal about 2 inches closer to the floor board. The adjustable pedals option only move them closer to the seat from the normal stock position.
Old Jul 20, 2005 | 09:51 AM
wrench007's Avatar
The only issue I noticed is that I find my right foot just barely on the throttle all the time. Many times, slipping off the pedal. If I catch myself. I'll "lift" and plant it where it should be. I wish the throttle pedal was a little closer to the brake pedal.
Old Jul 20, 2005 | 10:10 AM
3valve's Avatar
Originally Posted by Jub Jub
or is it just me?
Yep pretty much. Go drive a GM...nothins in the right place.
Old Jul 20, 2005 | 10:30 AM
SafetyDaveG's Avatar
Amen Wrench, I thought is was just me!
Dave
Old Jul 20, 2005 | 11:04 AM
vader716's Avatar
I never noticed a problem.
lariatf150,
I've always read that using two feet for driving an automatic is very unsafe. Were you taught that way or did you just naturally pick it up. I know most if not all driving schools warn against it.
Old Jul 20, 2005 | 11:22 AM
3valve's Avatar
lariatf150,
That's funny I thought the state driver's manual said use both feet. I hear both all the time. I drive with one foot. I always "stomp" on the brake if I use my left foot. Not coordinated enough I guess.
Old Jul 20, 2005 | 11:28 AM
suprpntr's Avatar
I always only use one foot, unless it is a manual transmission of course. 2 feet seems awkward to me...
Old Jul 20, 2005 | 11:34 AM
norman311's Avatar
I brake with my left foot. Started doing it driving here in the bumper to bumper traffic in Los Angeles. And no I DON'T rest my left foot on the pedal. My right foot would sometimes cramp up from having to brake so much in stop and go traffic. I could switch backto braking with my right foot but I find you can drive smoother using boot feet.
Old Jul 20, 2005 | 11:36 AM
mikebaby's Avatar
I've had no problems with it, and didn't notice anything odd about it. I'm 6'3" and wear a size 13.
mikebaby
Old Jul 20, 2005 | 11:44 AM
vader716's Avatar
Found this browsing the web just an
Why can’t I use the left foot for braking in an automatic car?
Here are four reasons why instructors teach to only use one foot in an automatic.
1. Under heavy braking the left foot must push against the floor to brace your body. You will have total control of brake, accelerator and steering during an emergency.
2. It is less confusing to switch from an automatic to a manual vehicle.
3. The left foot, resting on the the brake pedal, may inadvertently push down the brake pedal and light up the brake lights whilst accelerating.
4. There is less chance of a mixup between accelerator and brake. After a lifetime of using two feet, older drivers may get confused, pressing the wrong pedal. The ones that had used the right foot only all their lives are less likely to have trouble later on.
Old Jul 20, 2005 | 11:51 AM
3valve's Avatar
I'll concure with that.
Old Jul 20, 2005 | 12:20 PM
norman311's Avatar
All very good points and certainly something to consider.
1. If this was true why do race car drivers brake with two feet? I know not a good comparison but I wonder if professional racecar drivers brake with their left or right foot when they are off the track and driving a automatic.
2. If I switched between auto and manual regularly I believe I would use the right for braking to avoid the confusion.
3. Don't rest my foot on the brake and it is something I check.
4. Older drivers get everything mixed up. But like I said I can switch back to right foot braking only since this is how I started driving too.
I don't want to encourage nor do I recommend others to brake with their left foot. It's something I picked up because of the stop and go traffic. If I moved to a more rural area and could drive like a normal person I'd go back to right only.
