Oil drain plug?
Oil drain plug?
Is there a washer on the oil drain plug on 04 5.4l? I changed the oil & didn't see one. Want to make sure it didn't fall in the waste oil storage container. Thanks.
This thread makes me really appreciate the fumotovalve .
I just got to use it for the first time last week.
No more messing around with a drain plug.
My only regret is not getting the fumotovalve with the nipple.
Originally Posted by moller
Yep, I agree. A lower profile one would be better.
I've had the fumoto valve on three of my past vehicles and had no problems. They didn't see much off-road action, though.
For my F-150, I went with the Fram Sure Drain valve. On it, there aren't any levers to catch on something and accidentally open. Instead, you screw off a cap and hook a special hose (comes with the valve) to it and it drains really nice. It kinda works like a valve-stem on your tire...but only with oil, instead.
I'm not sure what part number it is (it wasn't listed for the 5.4 F-150 in the Fram catalog when I bought mine a year ago)...but it is the same as the one for a 99 Explorer with the 4.0 SOHC engine (I have one of those, too...and it takes the same drain plug as my f-150).
Hope this helps!
Dewy
Hope this helps!
Dewy
dewyrussler,
I had heard of the Fram Sure Drain. I just didn't know the details about it. It sounds like a pretty good idea. It has some protection and it is low profile. Just don't lose the hose and valve actuator. I guess you would need to take it with you if you got your oil changed at a shop or dealership. Otherwise, they would have to remove and reinstall the valve. I may just get one of these and try it out. Advance Auto has them on their website. The Fram part number for the 04-05 F150 with 5.4(3Valve) is SD2.
