rear end bounce
Old Jun 22, 2005 | 01:15 PM
bofer's Avatar
rear end bounce
is this normal, i was goofing around in some dirt the other day, in 2wheel drive and i started spinnin, nothing big just some soft sand, so i stayed on the gas, the rear diff locked up and then the back of my truck started bouncin. is this normal of loocking diffs or no. it only does it when im going slow and staying on the gas, if i floor it, its smooth and the tires just spin, whats with this?
Old Jun 22, 2005 | 01:39 PM
J-150's Avatar
between screwing around in the dirt and having pull contests with Rams, you've probably buggered up your diff.
Old Jun 22, 2005 | 01:41 PM
ThumperMX113's Avatar
I think I know what your talking about but it does it to me no matter if I floor it or just try to pull out slow. Soon as you put some weight in the bed it won't do it, at least with me.
Old Jun 22, 2005 | 04:11 PM
inbred's Avatar
a better description would help, but it sounds like axle wrap to me.
Old Jun 22, 2005 | 10:40 PM
bofer's Avatar
yeah, thats what i was thinkin. and as soon as i put weight in the bed it doesnt do it either.
By the way, its done it since i have had the truck
Old Jun 22, 2005 | 10:53 PM
BalogUK's Avatar
yea i start to notice when im down to about a quarter tank, i start bouncin if i take a corner quickly- (ive got the 36 gal tanks and it extends pretty deep into the bed - fill that bad boy up and it doesnt budge!
Old Jun 22, 2005 | 10:55 PM
PG4x4's Avatar
yea thats axle wrap, only way to get outta that is traction bars. I wouldn't continue todo it else you could bust a u-joint & when you are spinning and hooking up you will kill your posi fast.
