anyone have a sway bar on there ride ?
Old Jun 18, 2005 | 02:37 PM
bigyellowtruck1's Avatar
Has anyone put a sway bar on there ride, and if so does it handle better ?
Old Jun 18, 2005 | 02:53 PM
MPBTim's Avatar
Do our trucks not come with them?
Old Jun 18, 2005 | 02:57 PM
asinatra's Avatar
front does, he is talking about the rear
suspensionconnection.com
Old Jun 18, 2005 | 03:12 PM
MPBTim's Avatar
thanks...I feel kind of stupid now.
Old Jun 18, 2005 | 03:21 PM
porkchop's Avatar
If you find your truck starting to tip over in an apex then you're probably going a little too fast.
Seriously though, for the street I guess it's ok to put in a rear anti-roll bar. However, if you take it off-roading then it would be a liability since it would drastically limit rear wheel articulation on uneven terrain which means you would have to disconnect them so that they don't bind. The new Dodge Powerwagon has this feature where you can electronically disconnect the anti-roll bar(s) from inside the cab before leaving the pavement.
Old Jun 20, 2005 | 04:39 AM
Michael Joseph's Avatar
i've installed a hellwig rear bar. i do a lot of back road driving and it definitly is better than stock. ride quality was not affected, but handling was greatly improved. no problem with the install other than the kit missing a nylox nut.
Old Jun 21, 2005 | 03:31 PM
fujio001's Avatar
I also have a Hellwig on the rear and have to say the ride is vastly improved in the corners. You will find how you have to adjust your steering in a corner is also quite a bit different. Cornering is much flatter and predictable. i also changed out the shocks to Bilsteins and the whole package makes it much more stable especially at highway speeds. Comfort is the same to me. The only problem now is I feel the spring rates could be a bit firmer(working on that now) and the tires are maxing out their grip. I will probably change out the front spings in front and get a set of helper springs for the rear to stiffen it up a bit. New tires would also help. The stock BF tires suck!
