Message Center
Old Jun 17, 2005 | 08:51 AM
mw1063's Avatar
Message Center
I have heard the message centers on the fx4's can tell you a ton of information (i.e. actual mph etc.) by holding down a certain button while starting. In another tread it was dtermined that this did not work on the Lariat's. Does anyone know how to get this to work on the Lariat's?
Old Jun 17, 2005 | 09:50 AM
suncoast ford's Avatar
HUH??????????
Check your speedo for actual mph.............
Old Jun 17, 2005 | 10:25 AM
MAXXIS2001SCREW's Avatar
Your actual MPH while starting your truck is zero, I do know that much
Old Jun 17, 2005 | 11:02 AM
BigTRQ's Avatar
Hold down the trip reset button as you turn the key. Where your odometer usually displays, it will first ask (I think) "Check Gauges". A push of the reset button cycles the gauges right, then back to normal operating order. Continued pushes of the reset button get your a digital tach (useful for the XL folks) among other things. Very cool stuff!
-Travis
Old Jun 17, 2005 | 11:05 AM
ChrisAdams's Avatar
I have a Scangauge on my truck, and there is always a difference between what the PCM thinks your speed is, and what the needle says. That's with two IP's. Neither speedo was closer than 2 mph at 60. The original one, with the original tires, reported 3-4 mph faster than the PCM at 70.
Now, after putting slightly larger tires on, when the PCM thinks I'm doing 70, the speedo says 69. My GPS says 68.
Oh well, nobodys Speedo is all that accurate.
Chris
Old Jun 17, 2005 | 01:19 PM
mw1063's Avatar
MAXXIS2001SCREWQuote
Your actual MPH while starting your truck is zero, I do know that much. ....
suncoast ford
Qoute
HUH??????????
Where do you find all of this usefull information; I had never thought of either one of these ideas. You two are the absolute smartest prople I know. I am so glad you responded to my thread.
Old Jun 17, 2005 | 01:58 PM
ChrisAdams's Avatar
suncoast ford
Qoute
HUH??????????
I think Maxx was refering to the fact that our speedo claims 10 mph or nothing.
Sorta pointing out that there is no attempt to make them accurate, if you notice the order of the posts he was kinda pointing out Suncoasts error.
BigTRQ of course had the answer you wanted.
I've never actually done the push reset thing, having the Scanguage, I never bothered.
Hope it works out for you
Chris
Old Jun 17, 2005 | 02:09 PM
MooseRLP's Avatar
it even gives you your volatage meter and RPM. And about 30 other things which I dont understand what they mean
Old Jun 17, 2005 | 10:16 PM
1969Mach's Avatar
Thumbs up
Wow. That's cool. Some of the other things were fuel pressure, H2O temp (I think), tranny fluid pressure, speed, dash bulb check,and then like you said, a bunch of codes. Now if we could just find a list of what those codes are, we could really be dangerous!
Thanks BigTRQ!!!! That's cool.
Old Jun 17, 2005 | 11:29 PM
Rockpick's Avatar
Moderator &
-Travis
Thanks for posting this info Travis!
Old Jun 18, 2005 | 12:19 PM
mw1063's Avatar
This does not work on the Lariats. Does anyone know how to do this on the Lariat.
Old Jun 19, 2005 | 04:57 PM
mw1063's Avatar
Anyone?
Old Jun 20, 2005 | 01:49 PM
RjA150's Avatar
just went out at lunch and tried it in my XL and yep, it works. Now my question is, are we gonna screw something up by doing this? I dont want to take my truck in for some warranty work sometime and have them say oh your warranties void because you've changed some settings in the computer or something? It will be nice to use when I am towing a light load and want to use over drive, can tell if its shifting in and out.
Old Jun 20, 2005 | 01:51 PM
BigTRQ's Avatar
To the best of my knowledge, this is a "read-only" set-up, so going into it shouldn't change anything. You're just reading what the PCM is getting as info/dishing out.
-Travis
Old Jun 20, 2005 | 02:21 PM
Smokeneck's Avatar
Yeah, you learn something new every day. I didn't know it had a digital tach... thanks!
