Bed Rails
Old Jun 8, 2005 | 08:51 AM
MHK's Avatar
MHK
Smile Bed Rails
Has anyone self installed bed rails on a short bed flareside WITHOUT the popout holes in the plastic on top of the bed sides?
How do you get the plastic bed side covers off?
I want to see if there are stake holes under the plastic. THANKS, MH
Old Jun 8, 2005 | 09:08 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
97-03 Flaresides didn't have stakepockets.
I would think that if there isn't an access square in the plastic cover then there isn't a pocket underneath.
You should see the buldge in the inside of the bed wall, if it was there.
Old Jun 8, 2005 | 10:47 AM
J-150's Avatar
in 04 fleetside models there is a stake pocket but no access hole in the bed rail. To access it you'd need to remove the entire rail or cut a hole.
Dont know if there is on the flareside, but like Raoul said, if you can see the square bulge on the inside of the truck bed then there would be a stake hole.
Old Jun 8, 2005 | 04:22 PM
Raoul's Avatar
25 Year Member
Originally Posted by J-150
in 04 fleetside models there is a stake pocket but no access hole in the bed rail. ...
That is insanity to the nth degree.
No way Ford can justify doing crap like that.
I made wooden bedrails that use the stakepockets, not only do I popout the 'hole covers' but they pop back in whenever I want and you'd never know they were removed.
Old Jun 8, 2005 | 05:07 PM
J-150's Avatar
I thought it was a little dumb too. I had to do a double take that the stake pockets were there.
