i want bigger,wider tires for my 2wd,help!
i have a 2005 2wd supercrew,i want to give it a 4x4 look,but not too big because of my short wife.32-33 tall at the most.i plan to do a 2" leveling kit at the most.i want it to look a little wider and only want to do 17's,something like the eagle 178,or 186's.what size tire should i be trying to find to fit a 17 and give it the wider stance,but only going as tall as a 32-33.i like the way the nittos,mt and the bfg's look.
I personaly likd the bfg's. thay are a little spendy though. you can see th before and after looks of my bfgs which are 33's in my gallery. I also put in the 2.5 inch front end leveling kit. which is cheap. and dose a good job of slightly lifting the truck. between the 2 inch bigger tires and the 2.5 inch front lift it give the truck sits about 3.5 inches taller at the door sill. it will help especiallt for the wife to have running boards to help you get in. I use them always. it sits tall enough to give it that big truck feel but not so tall its a pain to get in and out.
