brake dust
Old Jun 4, 2005 | 11:43 PM
2005f150man's Avatar
brake dust
does anyone have a problem with the brake dust on the front rims. i cant stand that im cleaning them all the time. any help.
Old Jun 4, 2005 | 11:45 PM
PG4x4's Avatar
Mine has 6000kms on it and I'm notice more then normal brake dust. So I'm not sure if its from them being new and breaking in, or if they are cheap pads. I haven't even hauled a load or driven the truck hard yet.
Old Jun 4, 2005 | 11:51 PM
i got 7000miles on it and the brake dust is bad. im thinking replaceing the pads and hoping it will stop
Old Jun 4, 2005 | 11:58 PM
PG4x4's Avatar
What body style do you have? I went from a 04 supercrew to a 05 supercab med-box and I find its squirlish on the highways doing 100kmh/60mph. I tried putting my tires from 35 psi to 45 psi and nothing helped. It has almost caused me to lose control. You hit a bump on pavement and the back end wants to kick out. Feels like it was weight in the back, but that would kill the gas millage. On gravel its way worse then the 04 the back end wants to pass me all the time. Not very impressed. I road in my dads 03 superduty 350 diesel and the seats actually had some padding on them and the truck drove & rode way nicer.
Old Jun 5, 2005 | 12:00 AM
HIDPLANET's Avatar
Ive got a 2005 Lariat and dont have bad brake dust problems. Might be because I commonly use the tranny (automatic) to engine brake to slow down. Disable O/D, then from drive to 2nd to slow to a stop. Saves my brakes I guess.
Old Jun 5, 2005 | 12:27 AM
05LariatRik's Avatar
I have an '05 lariat SCrew with 3k miles, Brake dust has been a problem since it was new. I've read about this problem in many threads. IMO the only solution is to replace the pads with a different composite. I'm going to wear out the stock ones first. Just gotta wash your wheels more often
Old Jun 5, 2005 | 12:41 AM
etggolf's Avatar
Synthetic Pads...
Months ago, I questioned the same thing and got excellent advice on some synthetic brake pads. Do a search on the topic.
Old Jun 5, 2005 | 12:47 AM
Angry
i got 2005 stx supercab. thanks for the help. i guess i will wear these pads out than replace them. so i will keep washing
Old Jun 5, 2005 | 09:34 AM
kevhunt's Avatar
There are a couple of different aftermarket brake pads that will eliminate the dust problem. I have Akebono Proacts(ceramics) and no longer have the dust problem. Also, the OEMs were gouging the rotors. The new pads took care of that.
Others have had good luck with carbon/kevlar pads made by Hawk...Kevin
