5 miles per gallon
If i'm not mistaken, you posted on here prior to picking up the trailer and supposedly, "Ford" told you, you would be ok to tow this set-up. I'm still calling BS, but I really don't think you have much to complain about here. You're towing a trailer well over your trucks "sensible" abilities. Our trucks can pull a 80K lb Semi-Trailer out of the mud.....but should it be done.....probably not. I know it feels good to feel the part of a Ford Commercial, but in reality, your taxing your truck more than it should be.
I'd say 5-6mpg is good considering your pulling that much weight, surface area, load up and down mountains.
My 30' TT BP weighing ~7500 lbs loaded gives me 9-12 mpg depending on terrain. Not too bad considering.
any way It did well.
Originally Posted by Gene K
How tall is the trailer?
A 13' 4" Trailer gets much worse fuel mileage than a 10' 6" Trailer.
I suspect its the frontal area as much as the weight...
Originally Posted by nightranger
has anybody else gotten this bad of mileage? or pulled this large a load?
Originally Posted by tycreek
I just averaged 9mpg on 4 fill-ups with one tank under 8mpg. That first tank made me figure out quickly that driving with the TQconverter unlocked ment mpg goes way down. The rest of the tanks I tried to keep the TQ locked up as much as possible and all the rest were well over 9mpg. My load is a toy hauler trailer at over 7100lbs and the truck at just under 6500lbs. I would figure you're in at a similar total weight. This trip was up and down hills of the NW and before the many recent changes to the truck. I did have the 4.56 gears and exhaust in for that pull.
