where is the DRL resistor in the 04's
Old May 13, 2005 | 09:50 PM
Riken's Avatar
Question where is the DRL resistor in the 04's
is it in the same place as the earlier trucks...behind the d.side headlight?
any does removing it still work like the earlier trucks to disable them?
Old May 14, 2005 | 10:21 AM
Ascii's Avatar
I didnt know the lights ran during the day time??????????? Atleast mine dont. I could be really off or I bought a broken truck. I'll give a look and see if I can find it for you though.
Old May 15, 2005 | 10:22 PM
Ascii's Avatar
Hope This Helps..
Old May 15, 2005 | 10:27 PM
suncoast ford's Avatar
Great Post!
Old May 16, 2005 | 08:48 AM
jztbcz's Avatar
My XLT has the shutoff built right into the headlight switch.
I would think they would all be that way ??? Why would you have to search for some way to disable it other than just switching it off.. ??????
Old May 16, 2005 | 01:16 PM
crudeau's Avatar
mine is 05, but I don't have daytime lights either. Just a switch on the **** for the auto lights, which I leave on. They only come on when it's pretty dark. DRL only an option on 04's and not 05's?
Old May 16, 2005 | 02:38 PM
Cincy F150's Avatar
Daytime running lights are mandatory in Canada. I'm guessing Riken is from there. I know that a few members here have added the resistor to save money on there insurance. I think that the way insurance is set up in NJ you save a couple hunderd dollars a year adding this feature.
Old May 16, 2005 | 03:49 PM
crudeau's Avatar
so what does the resistor do then? run them at a lower voltage? or make it so they are always on? If it just lowers the voltage I would think I can just call my insurance now, and tell them I just drive with them on all the time.
Old May 16, 2005 | 10:21 PM
Riken's Avatar
those diagrams are great, where did you get them?
Old May 17, 2005 | 12:03 AM
powerage's Avatar
Don't take the resistor out. Right beside where the intake tube goes into the fender is a fuse/relay box. It only has like 3 or 4 relays in it. Pull the realy. That is all you have to do. I did it and it works great. I forget which one but if you look in your manual it says which one it is.
Old May 17, 2005 | 09:46 AM
Ascii's Avatar
Diagrams
I got the diagrams from ford dvd's I bought on Ebay.
Old May 17, 2005 | 02:02 PM
gregbj33's Avatar
hey guys,
i am interessted to know if i can add the DRL option. If i can what do i need to do. i have an 04 xlt. thanks in advance
greg
Old May 17, 2005 | 03:50 PM
Ascii's Avatar
I'd be willing to bet that it would be like just adding that relay since the trucks are basically the same wiring wise and all. Check and see if you have those wires and an empty relay spot under the hood. Run a meter and see if the leads are hot etc. etc.
Old Nov 21, 2005 | 09:22 AM
OldMan1's Avatar
Great pic. Can you post one for the Relay? I have a 04 and read many posts that don't seem to get to the point of where the Relay is. I have heard it is under the Steering Column behind a plate... Thanks!
Old Nov 21, 2005 | 10:46 AM
2001SUPERCREW's Avatar
I did that the day I got my truck 05, The wires are NOT in the 05 trucks. That really
was a shock not have them in it like on my 01. I guess in this case it was cheaper to not make just one harness. :santa:
You should make copies of that disc and sell it, I would buy one.
