Question about leveling kits on 2wd
Hey guys, I have a 2wd F150 and I was wondering about the 2 and 2.5 inch leveling kits for my truck. Would I be able to fit 285/70/17s without rub after the leveling kit on my truck?
Before someone else probably says it.... check the search feature out. But simply.... yes you can. There are alot of people with the combination on the board - gear slammer had it before his lift. There are even a few people with 2wd and the leveling kit who have even managed to put 35" tires on the stock rims with minimum rubbing - check out "Beaver Tricks" gallery and go to misc
I had a 2.5" autospring on, with 2" blocks in the back, and ran 285's for quite a while.
Then I got the 6" pro comp, and am saving up to buy 35's.
In response to the kanigit, BeaverTricks has the 6" lift like mine. We practically have identical trucks.
Lets put it this way...
I am lowered 2/5 and i run 285/50R20, thats 1.5in shorter diameter you want, and i dont rub when i am lowered. And all your doing is increasing the overall height so you can prob go bigger and should.
