new gears??
Old May 1, 2005 | 02:52 AM
bluehosefb90's Avatar
new gears??
just a question guys....i have been wanting to get some new gears in my truck for awhile and can find plenty of shops to install but cant find anybody who can get actual gears for my truck. Since i have seen plenty of people on here with the new gears(4.56 methinks i want) who do you order them from so i can get them?? any help would be appreciated!!!
Old May 1, 2005 | 02:59 AM
93xlt2wd's Avatar
How about Ebay. or Ford Motorsports??
btw....this is my 100 post...........woohooo Senior Member
Old May 1, 2005 | 06:09 AM
jpdadeo's Avatar
Troyer Performance sells gears; you have to call.
Old May 1, 2005 | 08:29 AM
YOMAN's Avatar
Try contact your area 4x4 shop?
YOMAN!
Old May 1, 2005 | 09:23 AM
Sal FX4's Avatar
Ford doesn't make anything past 3.73 for the 9.75. If your local shop can't find them, call Randy's Ring and Pinion. They are one of the few places that have the 4.56 for the ford 9.75 rear end.
Old May 1, 2005 | 06:47 PM
Baja4x4's Avatar
What engine do you have? From what I understand, if you have a 4.6 then you only have an 8.8 which gives you more options from Ford. Randy's Ring and Pinion has been recomended to me for where to by gears as well.
-Tim
Old May 1, 2005 | 09:11 PM
BlkButy's Avatar
Are these the right gears?
http://www.precisiongear.com/ford95bp.htm
or these?
https://www.f150online.com/forums/li...m/ford95bp.htm
Old May 1, 2005 | 09:30 PM
digipax's Avatar
or these?
Nope. Those gears are a softer more forgiving steel for high impact drag racing and are also the wrong size. The rears with a 5.4 use 9.75 and the fronts are 8.8 REVERSE CUT not the same as rear gear 8.8.You can get REVERSE CUT gears from Currie in alot of ratios, the 9 inch Reverse cuts from Currie will work in the front of these trucks as well(gear has same bolt pattern)as 8.8.
Try these guys here.
Front= http://www.reiderracing.com/ford88r.htm
Rear= http://www.reiderracing.com/ford934.htm
Old May 1, 2005 | 11:32 PM
BlkButy's Avatar
Thx for the info!
Old May 1, 2005 | 11:36 PM
Sal FX4's Avatar
Thx for the info!
Black, are you gonna get some new gears or what?!
Old May 2, 2005 | 07:34 AM
BlkButy's Avatar
Think I am going to have to so this beast can get off the line faster!
I think it would make a WORLD of difference!
Old May 2, 2005 | 01:34 PM
to update, troyer does not sell gears.....randy's ring and pinion have to get back to me on prices, they are sold out for at least two weeks and trying to beat reider's prices. Reider=199 for 4.56 gears + 149 for installation kit...about to call summit, jegs, and precision
jegs=do not have until richmond comes out
summit-214 for gears and 221 for kit...kinda high, but they do have a namebrand gear
precision and reider are the same company, but calling precision got a cost quote of 343.70 for gears and kit
anybody else got any gear places to check out?:santa:
