DDX7015 installed today
Old Apr 22, 2005 | 11:00 PM
countyboy04's Avatar
I installed the kenwood 7015 today, well almost finished it. I still have to install the pac swi-x. Install was pretty straight forward. I took it out for a test drive and it played the DVD while I was driving, I must have "accidentally" ground it to the wrong place.
A few questions though. Did everyone use the plastic brackets that came with the kit, they seem a little flimsy. And what trim piece did you use: the one that came with the head unit, or the one that came with the install kit?
Old Apr 22, 2005 | 11:02 PM
I tried to post a pic of the brackets but I guess it didn't work. You can click on the link to see what I am talking about though.
Old Apr 22, 2005 | 11:15 PM
Tuff4rd's Avatar
I used the plastic trim that came with the installation kit. And for the ground I used the same one that was used for the headunit, I just spliced them together.
Old Apr 23, 2005 | 11:30 AM
Does the headunit need any kind of support in the back?
Old Apr 23, 2005 | 01:38 PM
wernst's Avatar
If you look in the dash you will see where the factory head unit had a bolt/nipple that rested in a metal ring. Since the unit is so heavy I thought it would be good to have some just like this for my aftermarket.
I bought a long bolt and some thick plastic tubing. Feed the tube onto the bolt and trimmed off the end. Screwed it into the back of the DDX7015 unit. The tubing keeps the bolt from clanking. You can see there is a treaded hole back there. This work great. Let me know if you need more details.
Old Jun 3, 2005 | 11:05 AM
Sal FX4's Avatar
wernst, what size bolt and length did you use for the rear support?
Also, I notice a pop everytime i turn the HU on?? Its starting to get on my nerves. I hooked up the blue amp turn on wire fom the head unit to the metra harness (small square) Blue wire amp wire (there were 2 but only 1 was wired on Ford's side). I don't know if you ran into this problem but if not, maybe someone else knows the remedy?
Thanks!!!
