Musky smell from the Vents...
Old Apr 19, 2005 | 10:30 AM
SEU1's Avatar
Old Apr 19, 2005 | 12:17 PM
SAJEFFC's Avatar
Originally posted by Sick05Lariat
if my boss knew how much productivity he was losoing each day since i bought my new truck and found you guys......he'd probably fire my a$$
~sigh~ same here man. Guess we could all start our own company made up of fired F150online members!
Old Apr 19, 2005 | 08:47 PM
Preyhunter's Avatar
You have mildew in your ducts. As stated before, turn off the A/C before you reach your destination and switch to regular vent. This will help reduce the amount of condensation that will remain in the ducts that would be left if you run the A/C all the way to the destination. Also, leave it on vent when the vehicle is off (don't know if that makes a difference on auto climate control systems). In the meantime, get a can of Lysol, select vent using outside air and max the fan speed, then spray the Lysol into the fresh air intake vents. The fresh air vents are probably located in the wiper cowl area just like the older model trucks. The Lysol will help to kill off any mildew and mold you may currently have in the vent system.
Old Apr 19, 2005 | 09:43 PM
jpdadeo's Avatar
Originally posted by dzervit
How many miles & if over 15K have you replaced your cabin air filter? If you answer yes & no, I'd start with that.
What, no cabin filter?
Old Apr 19, 2005 | 11:54 PM
Justis01's Avatar
Get some Ozium (sp?). I used it in my Toyota Camry with mildew funk and it now has that nice fresh ricer smell inside when I use the ac.
Comes in a little spray can and you spray it in your vent intake a few times when running the ac.
Scott
Old Apr 20, 2005 | 12:24 PM
Sick05Lariat's Avatar
is that a for sure, or a probably?
Old Apr 20, 2005 | 04:58 PM
J-150's Avatar
and leave a nice April Fresh scent!
Old Apr 21, 2005 | 09:08 AM
snappylips's Avatar
Frigi-Freshworks wonders for stanky vents. It doesn't mask the smell, it kills the bacteria and mold spores causing the smell.
SL
Old Apr 21, 2005 | 09:56 AM
Preyhunter's Avatar
It's a probably. I haven't looked into it on my 04 cuz I haven't needed to. Someone else here should be able to confirm the location for you.
Yes, Ozium and Frigi-Fresh should work just as well, maybe even without the "April Fresh scent." You want something that will kill bacteria, mold, and mildew with disinfectant. That's why I suggested Lysol. Most people might have that around the house already. You want to kill that stuff off and take steps to prevent it from happening again.
Old Apr 21, 2005 | 04:05 PM
slippysmit's Avatar
Try this!
Wurth A/C and Heating System Cleaner.
You use this product in your intake vents and through your interior vents. All kinds of moisture, dirt, etc. can build up and create mildew and other nasty smells. This will help deodorize and clean!
-slippy
Old Apr 22, 2005 | 10:17 AM
Guigster's Avatar
What are you complaining about if you have a "musky" smell? Isn't musk a type of good smelling men's cologne?
Now if you had a "musty" smell, that I could understand.
Old Apr 22, 2005 | 10:42 AM
J-150's Avatar
i thought it was a fish... which would be bad... fish smell in your vents...
Old Apr 22, 2005 | 10:44 AM
Guigster's Avatar
There's really no good place for a fish smell.
Old Apr 22, 2005 | 10:47 AM
indyeng's Avatar
I spoke wth the Visteon design & release engineer for the P221 HVAC case and he informed me that our trucks DO NOT have a cabin filter. Also, he knows about the "musky" smell complaints. He agreed with Preyhunter about turning off your a/c before stopping the vehicle. However, instead of Lysol. He recommended going to Murray's, PepBoys etc and getting some biocide. Spraying that into the vents should solve the "musky" problem.
Old Apr 22, 2005 | 11:23 AM
snappylips's Avatar
Not true. When you charter a fishing boat, you hope like heck you smell fish by the end of the day!
SL
