Need Help Installing Bilsteins !
Just had installed
I had the Bilsteins installed in my FX4 last week.
The improvement is tremendous! I did not have a cushy ride before, and I still don't now, but it is much improved.
The ride is now firmer and smoother. You don't feel every bump and ripple, but you still feel the road. It still rides like a truck, but a much improved truck with this mod!
I would strongly suggest the Bilsteins as replacements for the OME, especially in the FX4.
Originally posted by kingfish51
when I go over speed bumps a little too fast, you can here the front end expand out to the limit.
Originally posted by digipax
Look, see and learn
http://www.off-road.com/ford/reviews...ein01.jpg.html[/IMG]
Look, see and learn
The rebound and compression should be valved differently so there will be a difference. Mount the OEM replacements with the shaft/boot up.
-Tim
How would the jounce and rebound valving rates change depending on a boots up or down configuration? As stated earlier I don't think it matters which way they are mounted and from past experence on a different model truck bilsteins were mounted boots down. However, if anyone is laying awake at night wondering about this before they install them, I would sugest calling someone who could definitivly answer your question such as Donahoe Racing, SDHQ, etc. I would listen to them before anyone posting on this thread, including myself. Actually if anyone calls them post what they said, I may reinstall mine boots up if they say to.
bilsteins can be mounted either way. I have a set of 5100 i am going to mount on my jeep this weekend and due to the configuration of the mounting hardware that came on these The rears will be boot down and the front will be boot up.
Originally posted by Baja4x4
Those are a totally different Bilstein shock. A reservoir shock mounts with the shaft down and emulsion style shocks(non-reservoir) mount with the shaft up.
-Tim
-Tim
[QUOTE]Originally posted by ThumperMX113
[B]If I was you I'd just call Blistein with all this different answers coming in.
I called Bilstein Friday there response after ten minutes on hold,was that they should be installed with the Stamped word Bilstein (its not the blue painted part but stamped into the shock body) oriented so that the wording is right side up. I looked on my shocks and the front shock is stamped on the bottom with shaft up the only way it can be installed anyway, the rear shocks are stamped on top with shaft down or boot on bottom.
[QUOTE=Alterra]
Bringing an old thread back to the top...
I received my Bilsteins yesterday. The rear shocks have the stamped and painted names right side up with boots up. Also, the boots are different on mine than in the photos I've seen here. The ones I've seen in pictures are the accordian-style boots sealed on both ends. Mine are smooth rubber sleeves that are attached on the rod end and free-floating on the other, just like the OEM hard plastic sleeves. I double checked the part numbers against what is listed on www.eshocks.com and the part numbers are the same. I suppose Bilstein revised these shocks.
Originally Posted by jaguar63
I contacted Bilstein when I went to put mine on. The boots go down. The lettering on the labels is correct end up so you can read them.
