Solution to Steering Wheel Shimmy/Vibration
Old Mar 22, 2005 | 02:59 PM
2tonecrew's Avatar
Hey guys, I might have a possible solution to all of our steering wheel troubles. I found on another site from a mechanic with the same issues. His fix was to adjust the preload on the rack and pinion system. There is a large nut like washer on the front of the rack directly inline with the steering shaft. Tighten it down all the way and back it off a quarter turn. I've got an appointment tomorrow with the dealer to try it out. Anyone had luck with this or know what I'm talking about!?? It's worth a shot!!!!!!!
Old Mar 22, 2005 | 03:00 PM
acticus's Avatar
Could be worth it, i would like to find a steering stablizer first
Old Mar 22, 2005 | 07:00 PM
Quintin's Avatar
There's a revised rack and pinion that already has a slightly tighter preload set between the rack and pinion gear for steering wheel nibble concerns.
Old Mar 23, 2005 | 12:49 AM
1brannon1's Avatar
tell me, in detail, how to complete the adjustment to the steering rack and pinion set-up. provide details and pics if possible. i will try it if someone will direct me.
Old Mar 23, 2005 | 05:23 AM
PC Poppy's Avatar
And where do we get a wrench big enough for that nut?
Old Mar 23, 2005 | 05:51 PM
2tonecrew's Avatar
This revised rack...do you have a part number on it or any type of information? Is ford aware of this new rack?
I don't have all the details yet, but as soon as they get it adjusted or look into it, I'll let you know how it turns out.
