Wiring XM Commander to DVD AUX
ok- I found it on Car Domain http://www.cardomain.com/item/AVXSIRSWB?ref=prgr
but cant find it at circuit city.... but thats where the pic you have linked is to. I only ask about circuit city because i got a gift card from there for a few bucks for christmas so i could use it...... if not ill order it from car domain. I just want to look at the back of my kenwood PnP and make sure it will work. Thanks so much for posting this
Originally posted by rambunctious
there are "headphone jack to rca" cables easily available. One may then need a longer rca patch chord to get all the way to the dvd if you don't park your sat radio in a bin.
Ramb
Ramb
This may be a silly question. but I want to make sure I'm going about this right.
Just got my Xm Commander. The Sat box has the 3.5mm "FM out" to be used with an FM modulator, but I notice it also has "audio out" which is a pair of RCA connectors. None of the specs I read mentioned these and the installation instructions don't mention them once.
But I assume, if I'm connecting to the RCAs on my dvd player, I can go from RCA to RCA instead of 3.5mm to RCA. Doesn't this make sense??
if the unit has the "rca" output option use that. it should be true "line level" output. I think the 3.5 mm fm out should be a much lower level as it is getting fed into the antennae (through fm modulator)
so use rca (which is the standard connector for "line" level) and you should be all set. it should be similar volume then as you switch from radio, to a dvd, to the aux.
try it out first with some short chords before you mount everything and route your longer wires.
hope this helps.
Ramb
hope this helps.
Ramb
We've got a SuperCrew with a sunroof, so we don't have the overhead rails for the DVD player. We also have the Audiophile 6-disc with the MP3 logo on it. It has a button that says "DVD". Can we use this to hook our iPod into our system?
What's on the back of the Audiophile head units? Is there a connection for a DVD player?
Just a simple line level connection into the head unit would be great.
Thanks in advance!
Mitch (new member)
'05 SuperCrew FX4
Thanks in advance!
Mitch (new member)
'05 SuperCrew FX4
so for now, factory dvd, or an fm modulator are the only ways to get aux inputs into the stereo.
hope this helps
Ramb
yes, it would be nice. but..... the 04 and on radios have what is called CANBuss. an electrical buss system that allows many things to communicate, including the audio system. the dvd or aux button is only for the factory dvd player. there is no aux input for a device like Ipod except through the factory DVD. companies are working on aux adapters for this CANBuss system, but they are backward engineering it and it is taking a long time.
hope this helps
Ramb
hope this helps
Ramb
For those interested in connecting an iPod, this might be an option:
http://peripheralelectronics.com/ipod2car/index.shtml
