Rear Cats?
Old Feb 25, 2005 | 09:33 PM
054door's Avatar
Question Rear Cats?
Anyone take out there rear cats? I want a little more sound. I got a 3 inch in 2.5 out flomaster with 2.5 tail pipes and 3.5 tips
Old Feb 25, 2005 | 09:38 PM
hellbound F-150's Avatar
Do it...I did it and it sounds great and added a good bit of power.
Old Feb 25, 2005 | 09:41 PM
054door's Avatar
You have a problem with o2 sensors or check engine light?
Old Feb 25, 2005 | 09:49 PM
Quintin's Avatar
Tampering with working emissions equipment is against the law, just for what it's worth. You may get check engine lights because as far as the 1-2 and 2-2 HEGOs know, the cat isn't doing it's job. Proceed at your own risk.
Old Mar 1, 2005 | 09:45 PM
DALXX2's Avatar
I took out the rear cats because i was unhappy with the sound of my 2 1/2" mandrel flowmaster cat back system. Ilove it now, everywhere I go people ask me what I have for an exhaust.
Old Mar 14, 2005 | 01:52 AM
khendrix2374's Avatar
What about the O2 Sensors on the cats? Do they not have any? I would assume that there are not O2 sensors on them since people are removing them.
Old Mar 14, 2005 | 07:21 AM
SVTErick's Avatar
no there are sensors. your just not using them. i removed all 4 of my cats
Old Mar 14, 2005 | 02:08 PM
Sound like a plan..
I guess I'll crawl under my truck and see what I can do about removing the rear cats.
Old Mar 14, 2005 | 05:48 PM
FATHERFORD's Avatar
Depends on the state.
Old Mar 14, 2005 | 06:34 PM
kd4crs's Avatar
Federal government EPA regulates auto emissions. Federal law supercedes any state law and applies to all 50 states and U. S. territories.
Old Mar 14, 2005 | 06:45 PM
gator25's Avatar
That's not totally true. If state emissions laws are stricter than federal requirements then the state law takes precedience. EG california.
Old Mar 14, 2005 | 06:46 PM
Never, ever in Kentucky will you get in trouble with the law for Emmisions standards...
ON th eother hand, muffler shops will not remove your Cats under penalty of law.
Old Mar 14, 2005 | 08:36 PM
kd4crs's Avatar
gator25,
You are right. The federal EPA regs specify the standards but allow the states to to set a higher standard if they choose. They may not go lower than the federal standard though. I stand corrected.
Old Mar 15, 2005 | 08:10 AM
nightranger's Avatar
I dont know where your at in Kentucky but in Tennessee you wont either. I'm just across the boarder from Middlesboro, Ky. in Cumberland Gap, Tn.
Old Mar 15, 2005 | 10:15 AM
jpdadeo's Avatar
If you removed all four cats and sensors, how does the PCM get feedback to run in closed-loop? Less than 81% throttle, and the engine up to normal operating temperature, you’re in closed-loop and the PCM is "listening" to the O2 sensors for A/F feedback control.
