How to disable the annoying low fuel buzzer
Why don't you just fill it up on your way home??? That would solve this problem. I usually fill up between 1/4 and 1/2. Why would you want to disconnect the fuel buzzer? It's trying to tell you to fill up or your going to be taking the Nike express (walking).
Originally posted by ScrewBall2004
once the low fuel dinger goes off you must be hitting the reset button to clear the "low fuel" in the message center.
Jeffery
Jeffery
i didn't know that. see, i learn something new here every day.
04fx4Scab,
I'm not sure how it works in a FX4 but to clear the "low fuel" message in the message center in a Lariat you have to press reset. FX4 doesn't have a message center...Right? So I'm not sure what you guys have to do.
Jeffery
Jeffery
Originally posted by bigdummy
Never even knew there was a "low fuel buzzer" on the truck. I got caught once running out of gas (when I was 16 and had no money) and don't ever want that to happen again. I am an adult now and a little more responsible.
I guess if you like riding around in an economy truck then the FX4 is for you. You FX4 owners rank right up there with the Chebby WT owners. FX4's even have power windows? The am radio option must be nice.
Jeffery
Jeffery
So, does anyone have an answer on how to disable the message center low fuel message? I didn't see anything in the owner's manual.
I dispise low fuel chimes, especially ones that repeat every 10 minutes. If I wanted to fill up the tank 50 miles sooner than I needed to, I'd have bought a smaller tank.
Originally posted by BHibbs
My FX4 has it. It'll just beep Once though and it goes off with close to a gallon in the tank. If you get this message I suggest you take dzervit's advise!
But, when my "miles to empty" is around 10-15 or so, the most I can put in the tank is 24-25 gallons. Having a 30 gallon tank, this leads me to believe that I should still have at around 5 gallons in reserve.
I have been pressing the reset button, to clear the low fuel message but, I will just leave it diaplay "low fuel" so it doesn't beep anymore.
I've run mine down to '0 miles until empty' and filled 'er up with 28.? gallons of the good stuff. In addition to the moron alert, they give you plenty of reserves to make it to your local fillin' station. This truck is pretty much stupid-proof.
On the economy trucks, like the FX4, they spent all of their efforts on making it look cool!!
Originally posted by TX Fx4
Ford did a good job in understanding the typical Lariat owner and designed the truck to suit them!
