2 Quick questions
2 Quick questions
1. Can you start the truck and then lock while running (to allow to warm up). And then use the key pad to open. Its just been too cold for me to actually try this.
2. Should the window lock switch on the driver's door be illuminated?
Question 1; you bet, that is one major advantage to having the key pad. Sometimes I will lock it and leave it running while I run into the Quick Trip to get my coffee in the morning.
Question 2: don't know!
To lock the door while its running, make sure the passenger side door is locked and then push the drivers side door lock down manually. If you use the door lock button, the door will unlock when you close it.
Be careful though. In Maryland we I live, over 1/3 of all stolen cars are stolen while running unattended.
Also for the ones that don't know after you push in the #s to unlock your doors, if you push 1-2 and 3-4 at the same time it will unlock all the doors.
All you need to do is a by an alarm with starter and you wont have to press any buttons except the one on the remote. As well you wont have to worry about leaving a key in the ignition.
If by chance some moron does try to steal your truck as soon as they touch the gas, the engine turns off.
Much easier than pressing this button, that button, and all the other buttons.
Later Trev
Later Trev
Later Trev
Later Trev
Originally posted by RamSS/T
You can also push the 6-7 and 8-9 buttons at the same time to lock them.
1. Mine dosent light either.
2. Yes,yes you can. I recommend remembering the factory code though, I set my own and it worked until I tried it the next day and it magically disappeared. I use mine all the time
