Leveling instuctions
Old Feb 14, 2005 | 02:50 PM
Ford Man 2001's Avatar
I have a 2004 fx4 s-crew. I want to build my own front leveling kit. I dont want to take it apart to make a template of what i need. i was wondering if anyone had done this and made the messurments if so can I have them?
Old Feb 14, 2005 | 03:14 PM
easterisland's Avatar
You aren't really making it yourself if you get the measurements from someone else.
Old Feb 14, 2005 | 03:30 PM
MRBIG's Avatar
Pick up a Daystar leveling kit and then "YOU" can install it yourself.
Its not like the old days of doing a body lift with shopping cart wheels.
Old Feb 14, 2005 | 05:22 PM
khendrix2374's Avatar
I think it would be easy to make your own. Just get a piece of round aluminum stock, cut it down to 1-5/8" or 2", then take apart your shock assembly and measure the width of the three top screws/bolts.... Then you could drill them out and your done....
Should look somthing similar to this.
Old Feb 14, 2005 | 05:37 PM
jamzwayne's Avatar
I think it would still be a pain in the ****....that is unless you have the machine that cuts raw metels down....like they use for making wheels.
It's easier to just buy the parts now days.
Old Feb 14, 2005 | 05:48 PM
Serge's Avatar
easterisland, you dont really make much sense. Just because he wants the measurements doesent mean he's not making it himself. Thats like saying if you follow a cooking recipe then you having really cooked it yourself.....geeze
Old Feb 14, 2005 | 05:59 PM
If you have access to a band saw and a drill press, you could make a set of these is about 20 minutes.
Go to a local metal shop and buy some 4 inch round stock and start from there.
If I had the tools here, I would make em and sell them on Ebay myself.
Old Feb 14, 2005 | 06:48 PM
torresu's Avatar
I have one homemade set...
Old Feb 15, 2005 | 09:46 AM
jamzwayne's Avatar
DAMN
Thats pretty good, torresu.
Did you make those yourself?
Old Feb 15, 2005 | 08:24 PM
I have axcess to a full machine shop. I just need to know where to put the holes. How far apart ect...
Old Feb 15, 2005 | 08:35 PM
jpdadeo's Avatar
You should be able to figure hole placement by making up a mock template. The top of the strut assembly is exposed so accurate measurements can be taken. Go for it, it’s definitely doable.
Old Feb 16, 2005 | 12:09 AM
Try Play-Doh..... Make a round play-doh "pattie" and put it on top of the strut. Theres your're template.
