Ford finally admits vibration!!!!!!!
Just got a letter from Ford about my 2004 F150.
Due to vibration and harshness, they are extending the 12 month 12,000 mile tire warranty to 36/36,000.
I won my lemon law suit, but I thought everyone should know about this.
The letter said if you have any questions go to ownerconnection.com or call the customer relations line
Originally posted by gmascellino
its all on page 9 of the warranty guide, it just been extended to 36/36.
I don't believe I would be charged for the alignment and/or balancing until after 36/36.
The main reason for posting this was to help those people that are starting their dsb and lemon law procedures. Not to debate the merits of a tire warranty.
Ford finally admitting this is a step in favor for those trying to prove the vehicle is defective. Generating 3 TSBs and re-writing your tire warranty is not usually done if the vehicle is performing as designed. This helps you prove your case (well at least it was significant in my board's opinion).
Originally posted by Beefullo
I am new here (and a new owner mind you). What is this vibration you speak of?
I have had 0 problems with mine.
<double checked for spelling>
Ok, if this means that Ford is owning up to the vibe problem then doesn't it also mean that the tires are causing the vibe? I think there's a lot of folks on here that will tell you that their vibe can't be fixed by a new set of tires.
