need speaker help - crossover location
Old Feb 3, 2005 | 07:34 PM
aggie '01 F-150's Avatar
Exclamation need speaker help - crossover location
i have my panels off and i am trying to install my new speakers and i don't know where to put to crossover
anyone who has done this, please help
i popped off the window/lock cover but can't find a place to feed the wires through
Old Feb 3, 2005 | 07:41 PM
BREWDUDE's Avatar
A couple options...if the wires are long enough just mount them under the dash. I wire tied mine way up out of the way. You could also put them behind the head unit. Theres anough room back there for anything. I personally would keep them out of the doors. You dont want them to get in the way of your power windows. Good luck
jhartz's Avatar
3m 2-sided tape.... put them inside the door panel next to the speaker hole, there is a flat space there in both the front and rear doors..... and then they are well hidden.. But remember to wire tie or tape the wires out of the way of the power window regulator.. Just look and you will know what I mean....Hope this helps
Old Feb 3, 2005 | 08:41 PM
grayflare's Avatar
You can remove the window switch panel in the armrest and put them there if your crossovers arent too big. Then replace the panel. Thats where mine are.
Old Feb 3, 2005 | 08:51 PM
speedwolf's Avatar
See my pix. I put the under the door locks. You'll need to reroute the speaker wire so that it will fit a little nicer.
