3.55 vs. 7.73 Rear End
Old Jan 31, 2005 | 10:18 AM
BamaScrew's Avatar
could someone explain to me the difference b/t the 3.55 rear end and the 3.73
Old Jan 31, 2005 | 11:01 AM
dzervit's Avatar
The difference is 0.18. Or read how axles work... http://science.howstuffworks.com/gear-ratio.htm
Old Jan 31, 2005 | 12:39 PM
Beefullo's Avatar
Think of it in terms of a manual transmission (this is relative and hypothetical numbers as well)
Let's say the 3.73 gears are the standard:
1st gear
2nd gear
3rd gear
4th gear
With the 3.55 gear set it would be like having a
1.2 gear
2.2 gear
3.2 gear
4.2 gear
Now those aren't correctly proportional, but it atleast makes more sense. The 3.55 gears are better for gas mileage and the 3.73 gears are better for towing. That make sense?
Old Jan 31, 2005 | 12:57 PM
Corpsie's Avatar
Actually, I've read here that trucks with the 3.73 seem to get better city-driving fuel economy than those trucks with the 3.55 (Just a side note)
Old Jan 31, 2005 | 05:28 PM
Beefullo's Avatar
No you haven't. Shut up.
Old Jan 31, 2005 | 07:18 PM
04 RED LARIAT's Avatar
Old Jan 31, 2005 | 07:44 PM
rubrnek's Avatar
Holy sh#t, that was funny!!!!!
Old Jan 31, 2005 | 07:53 PM
jpdadeo's Avatar
With a 3:55 axle ratio the drive shaft will rotate 3.55 (approximately 3 ½ times) for every one rotation of the rear tire. And the same formula would be used for the 3:73 which would mean that the drive shaft would rotate 3.73 (approximately 3 ¾ times) for every one rotation of the rear tire.
Old Jan 31, 2005 | 07:55 PM
tlouie32's Avatar
OMG!!!!!!!
