Engine Knock
Old Jan 28, 2005 | 09:47 AM
ARR's Avatar
ARR
Engine Knock
This morning going to work I noticed that the engine had a knocking noise to it. The weather has been cold and the noise went away after a few minutes. Could this be piston slap? It almost sounds like a diesel engine. It just turned 6500 miles with no noise issues until now.
Old Jan 28, 2005 | 09:50 AM
jamzwayne's Avatar
Hmmm....when was the last time you filled the truck up? Bad gas maybe? Have you checked the oil level?
Old Jan 28, 2005 | 10:36 AM
FATHERFORD's Avatar
When you said cold and diesel engine, piston slap came directly in my head.
Old Jan 28, 2005 | 10:45 AM
Blues001's Avatar
For the first few months after I bought my truck I was aware of that same sound. However since I stopped going to the McDonalds drive thru every morning, I no longer hear the diesel engine sound. Same thing with my fan, it revs up and down when cold. But only noticeable at the drive thru. I would not worry about it. I think its normal.
Old Jan 28, 2005 | 01:01 PM
ak_1fitty's Avatar
mine was doing something similar but it turned out to be a misfire... reflashed the pcm and now its gone... just a suggestion
Old Jan 28, 2005 | 01:54 PM
CaseyKM28's Avatar
Injectors maybe?
