Binding brakes
Binding brakes
Has anybody else had a problem with their brakes binding up? It happens every time I drive through deep snow. The snow packs into the wheels and seems to cause this problem. It only happens after I park the truck for a few hours(like overnight or at work), Then when I push the brake to put it in gear, sometimes they bind so bad that I can push the throttle almost 1/2 way down before they pop free and the truck moves. then they seem grabby for a while afterwards.
Anybody got 2 cents to contribute to the cause?
I had the exact same thing happen to me after launching my boat with the 200 f-150. I would hjose the wheels down and park and 3 hours later they would bind. I started putting wheel chocks after I would hose the wheels down. There is not much you can do other than make sure that your abs still works. Mine did not and I had to have it serviced.
