ADVICE, on leveling kit rims tires grille PLEASE!
Old Jan 19, 2005 | 03:33 PM
CobraUtah's Avatar
Okay when the taxes come back I'm going to go for it. I also need to know where to buy all this stuff.
I need to know the top brands for billet grilles. I'm wanting the type that do not have the ford emblem in the center. I want both upper and lower billet.
On the leveling kit I want good quality and whatever comes the closest to truly being level. Autospring, daystar, what?
I've decided on mikey thompson wheels classic II's. However I am going with 17's x 9 and running 35's so can someone tell me and explain to me the backspacing I need. Also what is the bolt pattern? I don't want to lift my truck but I'm told that with a leveling kit I can run 35's is this true?
I'm wanting advice opinions on tires. I think I've heard that the quietest in a 35 would be the BFG at's is that true. I love the look of the mikey thompson baja claws but the look like they would be hella loud. Any other suggestions on tires would be appreciated.
Old Jan 19, 2005 | 03:38 PM
HHIFX4's Avatar
all i can do is help on the leveling kit, i have the daystar 2.5 and as far as i can tell it is about as level as you can get i got it from truckcandy.com. i have also heard of some people running 35's but you might get some rubbing so you might need to trim up a little bit. not much input but hope it helps.
Old Jan 19, 2005 | 03:48 PM
jperea's Avatar
Billet grilles: Iwent with Stull - Came out nice with upper and lower. The grilles don't have the emblem when they arrive. You take the one off of your OEM grille and install it on the billet.
You may have some slight rubbing with 35" and just a leveling kit. Do a search and you'll see what the biggest tires are that you can get under there. Take a look at the 325/60 R18 Nitto Terra grappler. Those are pretty close to 35"s. Go with about a 5" backspace if possible. Lug pattern is 6 on 135mm.
Good luck and post pics!! JP
