Whistle resonance while accelerating
It was -3'f here in Ma this morning. Coldest to date for my F-150. As I was accelerating I heard a higher pitched frequency. It was a pretty loud resonance sounding as if it was coming from the dash. Could be engine, I’m not sure. The frequency was close to what a wet glass would sound like when you rub it. It only happened between 40 to 50mph and only during a mild acceleration. It was still happening after 30 min of driving. Anyone have a clue?
Nothing’s going to sound right in 3° weather. It could be the serpentine belt or any of the pulleys; (alternator, water pump, etc.) if it still does it when the temp. warms up you might have a problem.
the cold the cold the cold......... i ignore most weird sounds during the EXTREME cold... and ya it was the coldest day so far
for my truck too.. unless something is actually broke i would just
drive on...... MOTHER NATURE IS A BE-ARCH ...
Screech!
I believe it's the power steering pump, all my Fords screamed at me in the extreme cold. Especially my Ranger. Between the PS pump and the throwout bearing, It sounded like a cat fight until things loosened up. just my 2 cents.
Hoss
Hoss
Its probably just your air intake as mine whistles all the time whenever i step on the gas....but its because i have the air raid throttle body spacer installed. I hardly notice it now though, but when i first put it on i was ready to rip it out the same day.
As for cold weather, i wont even bother talkin about that.
Later Trev
P.S. Good thing my truck starts on the first try even when its minus 35 celcious. Thank god my car starter is workin now or i would have to break down and clean out my garage and make room for my truck.
Later Trev
i heard it this morning as well....o degrees in allentown this morning......about 9 when i left work this afternoon with heavy snows......i think it is the cold just effecting something....not as noticeable when it warmed up a little then later nothing. i checked my powersteering level and it is at the low mark.....should i actually fill it to the full mark? and is there a specific recomendation?
