20"s with AT or mud tires???
Old Jan 18, 2005 | 02:01 PM
1BadFX4's Avatar
i wanna get some soon, anyone got any pics? i need 2 find a good wheel 2 get, with a 5" backspacing so they dont stick out far.....
Old Jan 18, 2005 | 02:20 PM
easterisland's Avatar
Get some centerline crossfires. They don't stick out very far but I think they have 6" backspace and measure 20x8.5.
Mine are 17x8.5 and as you can see the 305mm wide tires don't stick out too far.
Old Jan 18, 2005 | 02:54 PM
1BadFX4's Avatar
where did u buy them and ur tires at??? they look good
Old Jan 18, 2005 | 03:08 PM
04SCREW98COBRA's Avatar
1BADFX4- I ordered Centerline Crossfire 20's with 305 55 20 Nitto Terra Grappler Tires. They just came in and I am having them mounted and balanced tomorrow. They should be on my truck by Thursday!
I am also installing the Autospring 2inch front lift because there is no way these wheels will fit without it.
Go to Centerlines website and go the the pictures section and click on "Trucks." Go to the bottom and you will see three pictures of these wheels on F-150's.
NOTE: They look even better in person!
Old Jan 18, 2005 | 03:10 PM
Wheels from centerline and tires from a wholesale tire distributer.
I do not think goodyear makes the mtr in 20inch but I think nitto makes an AT that may work. Because there is so much backspacing a really wide tire will be very close to the upper control arm with thes 305's it is pretty close. You could probably get away with a 12.5" or 315mm wide tire but nothing bigger.
nitto terra grappler 305/55/20 33" or the smaller 305/50/20(which is rated for the wheel @8.5 inches wide) 32".
discount tire direct sells them for 260 305/55/20 and $235 for the 305/50/20 shipped.
I don't like BFG AT's but they may make one...
Old Jan 18, 2005 | 03:55 PM
1BadFX4's Avatar
04screw98cobra, be sure to post pics man, also, how much did it run u for wheels/tires??? i've been tryin to find the cheapest place to get them?
Old Jan 18, 2005 | 04:13 PM
I seriously doubt you can get the wheels cheaper from anyone other than centerline unless you now a centerline wholesale distributer.
As far as the nittos discount tire is usually always the cheapest on the nittos. You can try online tires but usually they tae longer to ship and on some of their nittos they are more expensive.
Old Jan 18, 2005 | 04:25 PM
1BADFX4- I paid just over $2K for the wheels and tires. I got the tires from discount tire and the wheels I got from a local speed shop (who is a Centerline dealer). For the $$ you just can't beat these wheels/tires!
Be aware though, they are aluminum and will require polishing frequently.
Old Jan 18, 2005 | 04:54 PM
1BadFX4's Avatar
how hard would it be to find any other 20"s with atleast a 5" backspacing?? i really like the centerlines but, iam alittle shy of 2G's for wheels and tires....
Old Jan 18, 2005 | 04:55 PM
1BadFX4's Avatar
when u get them on man, be sure to post me a pic, it will look awsome!!! then again, seeing it might make me spend 2G forsure!!! lol
Old Jan 18, 2005 | 05:18 PM
I don't thin you are going to find any 20" wheel and 33" AT tire for less than around 2 thousand dollars(which is about $250/wheel and $250/tire).
Now if you want a 17" wheel and tire you could go nitto terra grappler AT 295/70/17 which cost around $165 each shipped and you can get all sorts of wheels...the centerlines direct for $197 plus $20 each shipped...
They would loo good and sit inside the fender.
Old Jan 18, 2005 | 05:21 PM
ThumperMX113's Avatar
Where did you find that price of $165 on the Nittos?
Im going with the MB Motoring Vapor 18" for my truck with either 33" Wrangler M/Ts or the 33" Nittos depending on which ever is cheaper.
Old Jan 18, 2005 | 05:42 PM
1BadFX4's Avatar
yeah, where can i get 296/70/17 nittos for that price???
Old Jan 18, 2005 | 05:44 PM
Sorry I was woring from memory. The price is $153 shipped.
