problems starting
Old Jan 18, 2005 | 10:32 AM
easterisland's Avatar
Question problems starting
I tried to start my truc_ this morning about 915 am about 15 degrees outside and it would just clic_ once with each turn of the ey. It wouldn't turn over. The lights and radio and all wor_ed. I called for roadside assistance because my truc now has 113 miles. I went outside 5 minutes later and tried one more time and it turned over and started on the first try. Is there a problem with the starter or relay or something?
2004 4.6L stx 4x4
(sorry the letter 'cay' is stuc on the _eyboard
Old Jan 18, 2005 | 10:43 AM
jztbcz's Avatar
the cold just makes things act weird i found, but maybe your pos
cable on the starter could use a check... just an idea
Old Jan 18, 2005 | 10:19 PM
chandlerdelinks's Avatar
your truck in Boston
How's it treating you?
Old Jan 18, 2005 | 10:29 PM
Tbird69's Avatar
It's your code key. If you have it on a ring with all your other keys that will cause interference and cause the problem you had.
