Hummer H2 Tires & Wheels Will they Fit?
Old Jan 14, 2005 | 10:47 AM
MHP's Avatar
MHP
I have a chance to get a set of wheels and tires off an H2. $ 400.00 for the whole set. Will they fit on my 04 F-150 with a Daystar leveling kit , tires are 315 70R17 BFG all terrain
Old Jan 14, 2005 | 10:51 AM
easterisland's Avatar
Re: Hummer H2 Tires & Wheels Will they Fit?
NO
Old Jan 14, 2005 | 10:57 AM
digipax's Avatar
The tires will fit just fine on the stock 17" wheels that come on these trucks. Buy them and take the Hummer wheels to the scrap yard, mount the tires and enjoy.
That's exacly what I did.
Old Jan 14, 2005 | 11:28 AM
MHP's Avatar
MHP
I am being told that the rims off the H2 have the same bolt pattern as F-150 stock and bolt right on. My concern is the size of the tire itself fitting with just the Daystar leveling kit since I believe the 315 70 R17 are 34" tall.
Old Jan 14, 2005 | 11:39 AM
Whoever told you that is ignorant. Which is why I replied NO to your first post.
Old Jan 14, 2005 | 11:42 AM
grumpsy's Avatar
I have a 1" square peg. Will it fit in a 1" diameter round hole?
Old Jan 14, 2005 | 12:13 PM
jdmclemore's Avatar
The H2 (and H1) have 8-bolt patterns while the F150 is a 6-bolt pattern.
Not even close!!
Old Jan 14, 2005 | 02:01 PM
EddyG88's Avatar
I have posted about hummer tires quite a bit around here. Do a search and you will get a ton of info on it and 315 tires. But no the hummer rim wont fit, and even if it did, it wont have the same backspacing. Do a search.
Old Jan 14, 2005 | 03:50 PM
wandell's Avatar
Exactly. Also the 315/70-17 BFG's are basically a 35x12.50-17.
Old Jan 14, 2005 | 06:06 PM
BREWDUDE's Avatar
Yes it will, Whats your point??
Old Jan 14, 2005 | 06:09 PM
SteveVFX4's Avatar
? ...no it won't? but a 1" diameter rod will fit in a 1" square hole!
Old Jan 14, 2005 | 09:17 PM
BREWDUDE's Avatar
= I was kiddin
But it will fit....
If you hit it hard enough
Old Jan 14, 2005 | 10:50 PM
Beaver Tricks's Avatar
Yes, the tires will fit with the leveling kit, with the stock FORD RIMS. I had the same set up before I added the suspension lift of 6"
The Hummer stock rims WILL NOT FIT.
Old Jan 15, 2005 | 06:08 PM
bigsherm77's Avatar
GM Rims on an F-150? Even if they did fit I don't think it's even legal where I live.
toddh's Avatar
Depends on how big of a hammer you use
