Pinion Angle Woes-Long
Old Mar 7, 2005 | 02:29 PM
  #31
jpdadeo's Avatar
Lowering the truck made the axle go up. Wouldn’t you then want to lower the pinion?
Old Mar 7, 2005 | 03:29 PM
  #32
jpdadeo's Avatar
DJM tech... "Which way does the shim go?"
Old Mar 7, 2005 | 07:50 PM
  #33
Quintin's Avatar
Mine has a slight driveline vibration since I installed the DJM 2" shackles on acceleration from 20-30 mph, any higher or lower than that and it's not there. It's not really that bad to me anyways, but it's noticeable.
Old Mar 7, 2005 | 07:58 PM
  #34
jpdadeo's Avatar
2° shims would put it back to where it was before you dropped it. I never installed them but it doesn’t appear to be that difficult of a job.
Old Jul 31, 2005 | 12:27 AM
  #35
kd4crs's Avatar
I just installed my Ground Force 2" shackles and got a slight low speed vibe. I installed the shims according to the instructions with the thick part facing the rear of the truck. The shims worked, no more vibe. The shims were marked as 2.5 degree.
Old Nov 25, 2005 | 04:48 PM
  #36
Duggins's Avatar
Duggins
Originally Posted by SVTErick
i would be willing to bet more than likely most people are 'feeling' something that isnt there. if one truck needs them then everyone with the DJM shackles and McGaughys lowering kit would need them. installing shims when their not needed can actually throw your driveshaft out of whack instead of helping it
I have a Styling Concepts 2" drop and I need the shims to correct the above said vibrations. Without the shims (pulled them out for 5k miles to vefiry) I get the same washboard vibs. DMJ gave me no help nor did BellTeck.
Who has ordered just 2 deg shims only for the '04 - 05 and installed them. I'm concerned about how they are secured.
Old Dec 5, 2005 | 04:00 AM
  #37
808-04XLTSC's Avatar
Shims...
I just purchased the 2-degree shims from StylingConcepts... tried to install it this weekend and realized after jacking up the truck and unbolting the U bolts that the opening on the shims were too narrow for the two "pins" on the leaf springs. Also, the opening on the shims are too short. I think the shims were made for the single pin leafs rather than the double pin leafs that the 04's and up have. I will have to end up opening up the slot on the shims by making it longer and wider to fit both pins. A real PITA! Oh BTW, my vibration occurs at about 24 - 26 mph. This was all after installing the shackles.
Old Dec 5, 2005 | 08:15 AM
  #38
kd4crs's Avatar
Yep, they sent you the wrong shims. The ones that came in my Ground Force kit were cut out properly for the 2 pin spring pack the 04-06's have. You might see if you can order them seperately. The part number for the 2" drop shackle kit I used is GRF-91200. If you get those shims, they fit with no cutting. Sorry to hear about the vibe, mine had it too after the drop until I shimmed it.
