got codes, what to do?
I installed the superchips 1714 and airaid intake last weekend and a week later today the check engine light was on. Checked the codes and they are:
01-P1000 monitor checks not complete more driving required
02-P0174 system too lean (bank2)
03-P0171 system too lean (bank1)
Probably due to the intake and the tube not being the up to date tube. Should I clear the continue to drive, clear the codes, take the tube off or what? Not too knowledgeable in this area. Need some help. Thanks
Originally posted by asinatra
What have your driving habits been like since the install ?
I was missing the L bracket that connects onto the side of the intake tube. I got that today and put that on. I then downloaded the stock program and it erased the DTC codes and then I reinstalled the 87 perf tune and the cel went away. So I will see what happens the next several days. I may have to call Airaid and have them ship me the updated tube.
boomer08,
Contact Airaid - tell them you're getting the "check engine" light. They will send you the new intake tube which will resolve the issue! I called them on Thursday, tube arrived on Monday - haven't seen the light since! And, with the temperature change, I was seeing the light every time I 'hit it'! Interesting design change to the tube, lower inner mold line now has an indenture which changes the air flow in to the throttle body intake.
