Soft Tonneau for cold weather
BSM,
Thanks for the info. I actually had already returned the tonneau. It's just a big jump from 150 to 300 plus bucks (for me anyway). Just trying to be as economical as possible because the truck gets used a lot as a truck and I don't want to spend a ton on a tonneau to abuse it, on off, on off etc.
Jason
Jason
Originally posted by bsm2001
...The best way to close in really cold weather is to remove a bow from the inside, leave the rear gate open and push the top rear bar toward the fron of the truck while at the same time pulling on the cover and snapping. Work form the center to the corners of the rear gate. Then snap the sides. You can put the bow back in later. Forget about the adjustable snaps - makes no difference - still very difficult to close.
I have the Extang soft cover on my '04 Screw. I had the luxury of parking the truck inside my garage with most of the snaps already done up. The next morning, I still had to use pliers to "pull" the vinyl far enough to snap the last remaining ones - and this was with the snaps set to winter mode. This is not unique to Extang soft tonneaus; I had to do the same thing with the Lund soft tonneau I bought for my '01 screw.
Re: Soft Tonneau for cold weather
Originally posted by ochoada
Hey Guys,
I have an 04 Scab and recently attempted to install Extang's snap on tonneau. I had the snaps set for winter and the bows in the lowest position and couldn't for the life of me get it snapped! Are any of Extang's lower priced tonneaus (not Roll top) good in cold weather? I haul a lot all year long and want something I won't have to wrestle with.
Jason
Hey Guys,
Jason
Just installed a TruxedoPlus combination toolbox/soft tonneau cover. Velcro on the side rails and a latch system over the tailgate. It's a "snap" to roll-up or close. Should be fairly water tight as well, but it hasn't rained yet, so can't say for sure.
Made in America, nice quality and workmanship. I really like the way it looks too.
GREGORY
GREGORY
I just got a carbon fiber look Tek Style and BARELY got it snapped.
I finally took a pair of pliers and put a rag over the jaws and used it to sneak the last couple of snaps on.
I don't know why you don't hear about Tek-Style stuff more often. I had one on my 2001, 2003 and now my 2004. I'll buy nothing else because I think the quality is so damn good.
Here's a pic of the carbon fiber look if you're interested.
-Fatz
-Fatz
I have a Truxedo cover on my F-150 too. Cost about $400, but it's worth it. It doesn't sag at all in the cold because of the support bars. I have a hobby farm, and my truck is used constantly to haul everything from chicken feed to fencing to lumber. Between the Truxedo and the spray-on bedliner, my truck performs well for the work I need to do.
Jake
Jake
Hey guys,
Thanks for all the help, info and pictures. I looked around a bit and it looks like the best way to keep the price down and get what I want (inexpensive tonneau) is to go for the extang tuff tonneau III. Looks like it has a tilting mechanism on the back rail so you can press in the j-hook and then rotate the whole back bar to snugg it up. Looks like the same idea as the ford factory with a pivoting rear rail.
jason
jason
To keep cost in line study the Truxedo concept and try to find a cover that fits withen your budget. Avoid the snaps and go with a top that secures either through velcro or some other mechanism. Also make sure that thereis a bar on the rear that acts as leverage to close - especially in the cold months. Like I said - I think Truxedo is the way to go but if your trying to save some cash look around for something similar. Good luck.
I have the Extang Black Max. I love the cover but it sucks to take it off and put it on in the winter. I know some guys who have these take them all the way off when they open it and put in someplace warm (inside the house) till they are ready to put it back on, this way it has a little more stretch.
Get the Ford snapLESS cover.
Thanks,
Scott
Justis01... It rolls up from back to front and has two straps that you tie it up with. Real easy to do. can do it myself if I stand in the bed as I roll it up. The cross members come off and go on real easy also. Just give it a little bend and they pop in and out. Im sure your gonna like it.
