intakes???
intakes???
i want to get a intake for my truck, i wanted to Volant, but people have been having CEL problems with them,, Volant suppose to be fixing it, my next choise was K&N, for those of u who have the k&n, did u go on smooth, and no problems with hoses or the CEL?? and how was the power gain, or MPG? did it gain or lose??
No cel for me either. Only had it on for about 400 miles. More power, nice growl when you hit the gas. Easy install, bolted right in, took about 2.5 hours, most of that in the dark with a flashlight
I got the K&N "Aircharger" as well. I've had it on for about 10k miles with no problems. It's hard to tell about the mpg's and performance, I installed the tuner and exhaust around the same time as the intake. I understand if you are in california, the k&n is not carb certified yet, but this intake is not having the same cel problems, confusion on what screws to use etc. as other intakes.
Also, correct me if I am wrong, but I think k&n has been around a lot longer than then other manufacturers and is very reputable. This is why I chose k&n.
Just my $.02.
Just my $.02.
i noticed it looks like the TB was moved from the upward position, is it? i thought that some intakes had elbows where u dont have to do that, i know the Volant does, and the AEM does....
If I was to make one complaint about the k&n it is that since the throttle body is raised up by the elbow, there is a wire (not sure what it does) on the left of the tb that is a little too taught for my taste. It connects but....
Did you have this problem MadMarty??
I contacted k&n and made them known to this issue.
