2004 Fx4 Screw
2004 Fx4 Screw
Well I brought it in for a service. 3000 kms. They changed the oil etc. Also they installed 2 new tires because of the slight vibe I have, I mean very slight. They also re flashed my computer because my throttle stuck and I almost hit a building. Hope that solves that problem. Also they ordered clutch packs for the rear end. Have these seem to be working for those of you with the shudder in the rear end while turning slow. I have only noticed this twice now. How long does it take to change these parts and do they seem to work???
The new clutch packs should get rid of any shudder in the rearend. The shudder is just your limited slip differential working too well. The new packs are slotted I believe and have less surface area for frictional forces. If the rearend has a noticable whine after instalation they F&*%ed up.
