6.32 backspacing on a 4x2 w/a 6" lift?
Old Nov 8, 2004 | 10:36 PM
jellytheory's Avatar
Is anyone running an 18" rim with 6.32" backspacing on a 4x2 with a 6" lift? Or, does anyone know if it can be done without having to use a spacer?
Thanks!
-Chris
Old Nov 9, 2004 | 05:06 AM
hovbuild's Avatar
You will not be able to use these..With a 6"lift you want a 4.5 backspace and -offset to clear the suspension. WHy would you want to lift a 4x2?
Old Nov 9, 2004 | 08:07 AM
wandell's Avatar
Why would you want to lift or lower any truck? Because it's cool! Stock sux!
Old Nov 9, 2004 | 08:23 AM
SVTErick's Avatar
i think itll work. im gonna run 34's with -8 offset wheels
Old Nov 9, 2004 | 01:18 PM
hovbuild's Avatar
If you put in a 6" lift tires will hit the wishbone if the wheels are over 4.5 backspace.... Trust me I know! I have a set of mojaves sitting in my shop that would be perfect for a 6" lift.....They stick out 87mm from the stock wheel and I went with an american eagle alloy that will work with a 2.5 leveling kit..178 18x9 that stick out 60mm from stock IMO the mojaves are way cooler but I don't want a 6" lift..60mm is bad enough without a lift but the 87mm is perfect with the 6" lift......I only wish I knew this before mounting tires on the mojave's.
