4x4 height?
Old Nov 8, 2004 | 08:44 AM
KaNigIt's Avatar
4x4 height?
I just have a general question. How much heigher are the 4x4 and Fx4 models than the 2wd STX models?
Old Nov 8, 2004 | 09:31 AM
jztbcz's Avatar
I don't think they are that much different, though i'm disappointed in the height of my 4x4 F-150 compared to the height my Jeep had. The lower control arms are much lower to the ground than my Jeep was, and considering how much higher up i'm sitting you'd think it would be better. The overpaid flunky
Ford design mugs dropping the ball.... Boy i'm venting about them
all over the place today...
Old Nov 8, 2004 | 09:38 AM
jpdadeo's Avatar
Re: 4x4 height?
The 4x4’s have a two-inch block between the rear axle and the leaf springs and are equipped with larger tires than the 4x2’s
Old Nov 8, 2004 | 10:46 AM
dzervit's Avatar
You know your comparing apples & oranges right?! Comical!! I'm really bummed about MPG's my 4x4 F150 gets compared to the Prius I had...
Old Nov 8, 2004 | 11:16 AM
Baja4x4's Avatar
Re: Re: 4x4 height?
Other then that, I believe the suspensions are the same...as in their is no difference that I have been able to come up with between a 2wd and 4wd front suspension.
-Tim
Old Nov 8, 2004 | 12:09 PM
asinatra's Avatar
1"
Old Nov 8, 2004 | 02:57 PM
fatman66's Avatar
like you would even fit in a prius (not that I would either...)
Old Nov 8, 2004 | 03:36 PM
J-150's Avatar
if you took that go-cart out of the bed it may actually burn some fuel...
Old Nov 8, 2004 | 04:44 PM
Superscrewd's Avatar
actually in the front I believe there is a difference. I was told the spindle is longer and so is the coil. I would say about two inches total difference in the front.
