HELP shmidty!!
Old Nov 2, 2004 | 05:34 PM
fordabbits's Avatar
Exclamation HELP shmidty!!
The person Im going through says that Rancho suggests that you put on reservoir shocks on the rear. Have you had ANY problems with the installation/function of your shocks?
Old Nov 3, 2004 | 03:26 PM
Baja4x4's Avatar
The only need you will ever have for reservoir shocks is if you travel offroad at high speeds for extended periods of time. The reservoir is to disapate heat and keep the shock at a cooler temp. which lets the shock continue to work properly.
-Tim
Old Nov 3, 2004 | 07:37 PM
fordabbits's Avatar
Thanks, I found out why he said I needed those. He said that if I used the regular 9000s, the exhaust would melt the boot. I told him that was bull **** because the muffler it about 7 inches away. And the pipe is about a foot away. He was probably trying to get me to buy more.
