1" body lift ????
Old Oct 30, 2004 | 11:20 AM
RED WING NUT's Avatar
Originally posted by SVTErick
i could also trim a bit of the fender but im concerned more with the tire hitting the control arm or something under there.
You won't hit the control arm with that offset.
Old Oct 30, 2004 | 11:23 AM
SVTErick's Avatar
so then with those wheels i should go with a 285/70/17 tire. and stretching it a 305/70/17 tire?
Old Oct 30, 2004 | 11:39 AM
Is your front end lifted? Do you already have the wheels? Is the wheel sticking out that much the look you want? If not then I would look to get something with around a +25 offset. Then you wouldn't have to worry about hitting the fender and sandblasting the side of your truck from the tires throwing up stuff. I could fit the 305 on mine but that offset you're talking about has me concerned. I think it will be real close when turning, if not hitting.
Old Oct 30, 2004 | 11:42 AM
SVTErick's Avatar
i dont know ive seen a bunch of other people running the same exact wheel. 1864-8994 17x9 Super Finish 6 on 135mm -8 mm 2100 lbs. 25 lbs. right now the truck is still lowered but im piecing it all together for whe i install the skyjacker 3" lift.
Old Oct 30, 2004 | 11:46 AM
SVTErick's Avatar
'Grunt' who is a member here is running the same wheel in 18x9 with a 33x13.5x18 tire.
If your front's not lifted, no way. If it is and you have seen people running these, you may be fine. But it's gonna be close. I went with something I knew would work and would have plenty of room.
Old Oct 30, 2004 | 11:47 AM
Same offset?
SVTErick's Avatar
nope +2 im confused as hell now.
Old Oct 30, 2004 | 11:51 AM
Here's how much his tires stick out. Is this what you want?
You need to ask him how close his 33's are to hitting the wheel well. He has a 2" lift I believe.
Old Oct 30, 2004 | 11:53 AM
I'm telling you, you don't want that -8 offset.
SVTErick's Avatar
yea i dont mind about the sticking out. i actually like that look. but then again his wheels are +2 offset would the -8 offset stick out more or less? but thats not what i care about i would like to know if i could go with a BFG 285/70/17 or stretch it to a 305/70/17 or 315/70/17. 3" lift up front and back.
Old Oct 30, 2004 | 11:59 AM
The -8 would stick out more which would bring the outside edge of the tire closer to hitting the back of the wheel well when turning. If you want those wheels and you have the 3" lift, go to a tire store that will mount the size you want and see if it clears. If not, have them try another.
Old Oct 30, 2004 | 12:05 PM
SVTErick's Avatar
what a weird scenerio. why would they make a wheel like that then?
Old Oct 30, 2004 | 12:43 PM
SVTErick's Avatar
so basically if i buy this wheel i have to run a 285/70/17 tire
Old Oct 30, 2004 | 03:27 PM
SVTErick
Here's some pics for you
