Truck bed vibration
Old Oct 21, 2004 | 03:35 PM
bigdoge8's Avatar
Truck bed vibration
Have 04 STX that has a excessive truck bed vibration. Nothing in the front end as others have stated. When driving and hit a bump seems to radiate vibration throughout whole back end of truck. Had all four tires repalced by dealer no help. Does anyone else have solution or simular problem?
Old Oct 21, 2004 | 03:56 PM
dzervit's Avatar
Cross post! See general forum... plenty of replies there...
Old Oct 21, 2004 | 04:14 PM
donaldpaul3's Avatar
Bed shake and vibration.
My Bed would shake violently whenever I hit bumps until my line-x was put in. Not sure of the bolts were loose (pre line-x removal/reinstall) or if the rattles are simply less noticable with the line-x. Either way, it is MUCH better now... normal bed shake everyone agrees with.
Old Oct 21, 2004 | 07:25 PM
J-150's Avatar
because the frame is so stiff, you are seeing flex in the body panels.
On a cheaper frame, those vibrations would be running through the frame into the cab area.
