How do you lift the front bumper to take away the gap?
Old Oct 20, 2004 | 10:29 PM
RamSS/T's Avatar
Forgive me if this is a stupid question (meaning the answer is loosen the bolts and push it up then retighten them) but I have seen a few trucks that have had the bumpers pushed up to the body lines, thus getting rid of the gap between the body and the front bumper. This is a very clean looking mod and I would like to do it. but I haven't had a chance to get under the truck yet and see if you can just unbolt the bumper and push it up....is that simple or is there more to it than that?
Old Oct 20, 2004 | 10:38 PM
asinatra's Avatar
easy way:
four bolts; 2 on each side, 18mm 3/4 drive wrench (i think), 2 friends pushing up and you tightening
Old Oct 20, 2004 | 10:46 PM
RamSS/T's Avatar
Originally posted by asinatra
easy way:
Thanks...sounds like a good mod to do this weekend!
Old Oct 20, 2004 | 10:48 PM
Bullitt4711's Avatar
hmmm... Anyone haves pics of this done from the side of the truck? I would be worried that it would cause the bumper to sit "higher" than the bottom side of the truck, and look kinda funny.
Old Oct 20, 2004 | 10:59 PM
RamSS/T's Avatar
Here are some pics of Chip Foose's F150 with the front bumper mod.
Old Oct 21, 2004 | 08:30 AM
EddyG88's Avatar
If you have a 4x4 and plan on using it, I wouldnt suggest doing that. I am not 100% sure but I thought the gap in the front was there as a vent and for room for play in high stress situations. If all you had to do was tighten the bolts, why wouldnt Ford do it?
Old Oct 21, 2004 | 09:35 AM
bluestang67's Avatar
your right Eddy the gap between the bottom bumper and the upper cover is to eliminate rubbing. Eventually it will wear a rub mark where ever it's in contact. Even though the frame is rigid it still has some flex in it. The cover will shake also being soft compound while driving.
