dash cleaning
I use "ProTech All-In-One" UV Protective spray. It doesnt leave a haze and it also protechs really well! I have the black interior FX4, so I had the problem with the haze on everything else I used. But this stuff works!
I just use a cotton towel that has been dipped in hot water, then wrung out. I use Plexus on the clear plastic over the instrument cluster. I also use a Dash Duster to keep the dust off in between interior cleanings.
Thanks alot, I've never seen pro tec around here but I'll look on the web and see if I can order some. I like the water idea to (it's cheap) The black really looks good when its not hazy.
I keep a 'Swiffer Duster' in my center storage. Whip it out (the Swiffer) and in 20 seconds you have a dustless dash. It rocks.
